Hi M,A friend of mine once built a canoe... (email fwd:)
Whitewater and Touringwww.ukriversguidebook.co.uk
Every time I decide to use spray foam I convince myself that I won't need plastic gloves. Every time I am wrong.
Why do I do this to myself? Now to wait for the stickiness to go away so I can peel it off...
It's not exothermic, it's actually slightly endothermic, which portion of this hatch do you think had some foam put in the void between the two sides?Regular PU foam in cans is a one part product, not a two part product. It is not exothermic. It uses moisture to cure and not heat (unlike epoxy resins and PU fillers). I have no idea what product was supposedly used in your link.
My son (he's a shopfitter) Had to do a emergency stop in his van. Foam gun flew can leaking foam, they managed to smother it with a old towel and dumped in a freshly emptied bin .
On way home saw bin pink foam flowed over the top and almost covering bin
