I have a double socket in my kitchen and I wish to add an electric oven 2.4kw (max) from that socket I noticed that a spur runs to a double socket that has the kettle running from it. Would the kettle and cooker overload it?
There are two sockets on one side of the kitchen and I wish to add an electric oven 2.4kw (max) but after checking the sockets I found one was a spur from the other.
I then realised that I could possibly overload it (example having a kettle on that side of the kitchen) would I be better to run a separate wire to the CU just for the oven.
