H
holmslaw
And the lighting circuit is on a 6A MCB.BAS how do you get a "potential 5KW load" from that arrangement? Afaict other than the lights everything in the garage is going through a 16A MCB.
Actually it's 6 "individual" sockets, but the number is unimportant. The CU in the garage has a 16A radial circuit with at least one socket outlet on it and a 13A FCU. I say at least one because it isn't clear from the diagram if the double outlet is connected to the load or the supply of the FCU, but again that's unimportant, because however it's connected we have a potential load on that radial of at least 26A.And of the seven individual 13A sockets, five are fed via a FCU.
No I'm not.Banal is having a bad day
The first is not true, and I'm not having a go - just responding to what you yourself actually wrote.he's desperate to have a go at me in any way possible.
1) I've made no insulting comments about people in the plumbing forum.And the mods have made him remove his insulting comments about people in the plumbing forum.
What I dislike is the practice of dragging irrelevant, off-topic disagreements from one thread to another, or of behaving irrationally towards someone because of grievances from other threads.Poor old BAS, he's so upset he's dragging comments from other threads into this one. If anyone else does it he blows his top.
It's clearly advised that one of the measures you can adopt to help ensure compliance with the regulation which requires you to avoid long overloads of parts of ring finals is to put immersion heaters on dedicated circuits, but there's no actual regulation requiring that even now.Originally putting an immersion heater on a ring circuit was correct and acceptable but now its clearly stated in the regs that it has its own circuit.
The old OSG [on site guide] 16th edition clearly states that 'Water heaters fitted to storage vessels in excess of 15 litres capacity,... , are to be supplied by their own separate circuit', this is what I have quoted from and applied as gospel BUT Interestingly there is NO quoted regulation.It's clearly advised that one of the measures you can adopt to help ensure compliance with the regulation which requires you to avoid long overloads of parts of ring finals is to put immersion heaters on dedicated circuits, but there's no actual regulation requiring that even now.Originally putting an immersion heater on a ring circuit was correct and acceptable but now its clearly stated in the regs that it has its own circuit.
But even if there was, as you say there'd be no obligation to make the existing arrangement comply. You can't argue that it wouldn't be the ideal thing to do, or that if starting from scratch it would be the way to go, but old installations are full of things which are not ideal, and decisions to change them have to be informed by how serious a problem they are, and how much it would cost to rectify.
In this situation I don't think it's a serious problem and it would be a non-trivial cost to put in a new circuit. If the OP wants to leave it I don't think he should worry about that decision.
SUNRAY";p="1700287 said:Have you looked as the picture?? No I thought not.yes
Ok since the lights are fixed loads I counted the lights at thier actual load (arround 1A) rather than thier breaker rating. That plus the 16A breaker for sockets gives a total of arround 17A16A + 6A = 22A
Which is higher than the 13A of a FCU but a lot less than the potential combined load an idiot can draw through a double socket.
