Spur off a spur
The only guidance I know is so you don't overbend the cables of moulded plugs and that's nowhere near 250mm.
What reg no are you referring too
Hi All,
Quick question.........
I had a new socket installed in my kitchen recently.
There was already a socket in the kitchen (a spur from the garage, with a double socket on), and the electrician took a spur from this spur and put another double socket on.
When I queried this I was told that, strictly speaking, this was not compliant but since I wasn't going to be running any super-heavy appliances then it would be OK.
Of course, I am not particularly happy with this.
I am not going to ask the guy to return, but I want an FCU placed in to make the work compliant.
My question is.....if I am putting a 13Amp FCU in, does it sit before the first (original) spur (so that the total limit for both sockets is 13Amp) or between the original spur and the new spur (just to limit the new spur to 13Amp)?
Many thanks for any help..............
could you run a cable from your new socket back into the garage and make them all into a ring
FGS.
READ:
at least 250mm above the worktop so they are above kettles, toasters etc, not behind them.
AGAIN:
AND AGAIN:
You are not understanding something.
We have read your post. We understand what you have written.
Now you read our posts again:
Where do you get the 250mm distance from?
I'm not referring to a reg. I am using common sense. Better not to have the sockets behind appliances so you can get to them easily.
It is the distance that puts them above kettles, toasters , etc that people have on kitchen worktops. At times I despair at posters lacking intelligence.
At times I despair of posters putting information on here that is just their belief, or understanding, or what THEY consider to be the "way to do it".
I am afraid that you are a prime example of
All we are asking is what is the regulation, or other dictate, that confirms this 250mm distance from (the one that only you seem to know about). So regulation number please.
At times I despair at posters throwing their opinions in as if they were meaningful
Pretty poor of your sparky to do this, particularly in a kitchen where its notifiable.
There are lots of knowledgeable people on here, so it would be interesting to see what others add.
My addition, then. Electrical work in a kitchen is not notifiable.
I will agree that the work is poor.
As I said there is no regulation.
They need to be at least 250mm above the worktop
You said NEED to be. What directive is that? The book of Winston?
It would have been much better if you had said "I suggest that you place them at least 250mm above the work top. I do this because........."
The way you wrote the original sentence indicated that it is a mandatory requirement.
