I've got a double socket on the outside wall at the back of my house (external IP rated socket), it's taking power from the kitchen ring which just happens to have a socket inside the building directly behind the socket on the outside -very handy. The external socket is on a spur from the internal socket. Some questions....
1. Is this within regulations? (ignoring the fact that the spur cable is bog standard 2.5 T+E which I'm sure is outside regs).
2. Given how close the two socket are (only the cavity wall thickness apart) would it not be better to break the ring and add the external socket in to the ring?
3. Perhaps this socket needs a separate circuit (or best practice would be to have a separate circuit)?
4. Perhaps you can use bog standard T & E to connect to external sockets if it's in a conduit? the cable running to mine has no such protection!
YES ..... - BC notified ages ago!
