nabby68 said:I have a kitchen socket that has a fused spur running of it which supplies some under unit lights. I would like to spur off this socket again with another power socket, is this allowable?
thats something i've seen people say a lot but i've never seen it backed up with a quote from the regs.andrew2022 said:you should only take 1 spur from a socket
plugwash said:thats something i've seen people say a lot but i've never seen it backed up with a quote from the regs.andrew2022 said:you should only take 1 spur from a socket
I'm not convinced...pdcelec said:But there is a reg which covers it in BS7671
pdcelec said:314-01-04
pdcelec said:A spur from the ring is just that a spur. A spur from a spur is a radial circuit. Therefore the radial circuit should be on its own protective device
