It's just as flexible as a round one surely?
sorry no.
do you have a square terminal and a square fire spigot to fit the square flue liner to?
I'll get those once I can find a square liner
Most people start with the fire and then buy a flue liner appropriate to the fire.
Are you competent to fit fires and test for safe combustion and flue operation?
Tony
So you think a square liner will do a better job than the 7 inch round one you have been told you need, believe me from experience it will be a very limited amount of chimneys that a square one will go down,
They are for purpose designed flue systems or perfectly straight chimneys
Who says I need a round one? A square one won't do the job better or worse than a round one. It's the area that's important.
Why should a flexible square liner only be for straight chimneys? It's just as flexible as a round one surely?
why???
What is your problem?? Why on earth do you think I want a flue liner?? To water the plants in my front garden? ****.
However, I'll tell you what a flue liner is for as you clearly want to know. Basically, when your old brick chimney isn't sound, if it's perhaps leaking carbon monoxide into properties above yours, you need to have it lined.
A flue liner, is something that is inserted into the brick chimney to...wait for it...LINE it, so the fumes go safely up the flue and out the pot at the top.
Anything else you want to know, little boy? I'm afraid the classroom is closed for now. Try tomorrow.
I'm actually after a steel flexible square flue liner, like this one: http://www.chimneylinerinc.com/images/squareliner.JPG
i didnt say it was, if you read my post again correctly, you will clearly see i made a statement (which is correct) taking it a step further, anyone who knows anything about it knows round is the preferred shape to assist POC's travelling up a flue to the terminal, so your statement that the area is more important than the shape is wrong, as a round and square flue of the same area will not evacuate the POC's at the same speed,A round flue isn't any more smooth than a square one
