Hope this is the best forum to use - there really should be a kitchen one?
I'm going to be having a new Howdens kitchen, and I want a tall (i.e. floor to ceiling) corner cupboard. There isn't space for the normal solution of an 800/900/1000 unit into the corner - the door on the accessible end would be about 300mm wide, so no carousel or magic corner would work.
The 931 L-shaped cabinet would be OK, but that's only a base unit, so I had an idea of stacking 3 on top of each other, like this
Rigidity should be OK, as I'd add a top, and there will be 18mm ply decor panels fixed to each side
And there's space at the back to screw vertical rails on
And lastly there will be tower units each side,
So I don't think it will wobble.
But the question is what do the experts here think?
Would it be an idea to add tops to the bottom and middle cabinets as well?
