just bought a secondhand combi from uk to replace my old one im assured it is in excellent working order and is arriving with flue fitting wall brackets etc-- if it dont work then we stay cold
my old combi is in a purpose built brick cabinet built on to the out side of our country cottage so access s simple via double doors,
bearing in mind this is rural portugal and not easy to get pipe fittings or for that matter qualified plumbers i will fit the boiler myself then get the lpg supplyer to fit the gas connection to the boiler. for safety safety safety safety
in the 80s i replaced a coal floor mounted boiler for a gas boiler with copper years ago also fitted a gas fire then called out the gas board to connect the gas test and fire it up everything turned out ok so i reckon i have some water plumbing diy savvi
i will disconnect the electrics and gas bottles drain off the water in the boiler and remove the old boiler and cut the four water pipes leading out from the bottom of the combi abot 8 inches down
and fit the replacement in its place and run the flue out of the existing hole in the wall .
ok heres the question
i want to run 4 flexi braided stainless compression water pipes fom the cut pipes then connect them about 12 inches each straight on to the boiler water pipes , i now its best to come of the boiler using copper but is it acceptable for me to try this ,
a bit of flexibility would come in handy on this diy job as we do
get small earth quakes in portugal in fact 1755 we had a sunami which took out every city including lisbon , ok thats enough of the history lesson
yes i know it dont look pretty but im more concerned about safety rather than presentation on this job--but i promise to fix the flexi pipes so they look as a bit of care and thinking has gone in to the job.
also will it be a straight forward pipe to old pipe join up be ok
or am i missing something here--
please keep answers on a positive and helpful note as im looking for help as im a long way from uk
hance a request on the diy forum
Cheers
Cheers
