I need to make a stair case. Straight, nothing fancy. A wall / closed stringer will be required on both sides until about 2/3 of the way down, when one of the walls stops. At this point I want the stringer on that side to become and open / cut stringer.
Obviously to make it open, the stringer needs to be notched and in doing so it is weakened. I want to know what regs / guidance there is for what the remaining height of the stringer should be (at the apex of the notch, as it were). But I can't find anything online. Nothing in Part K of the Regs either that I can see.
As ever, a picture paints a thousand words:
Cheers
Cheers
