Hi Folks, newbie here.
I've had an Ariston Micro Genus HE Type C Condensing Combi boiler for 2 years.
It has been serviced but not recently.
Since the last plumber came out to check my radiators as they were getting to maxuimum temperature things haven't been quite the same.
Now, the fault was an old radiator valve wasn't doing it's job and when he unscrewed the the top of the valve the radiators began to get really nice and hot again.
However, since he went, every now and then I would have the boiler running the hot water into the bath and it would just 'click off' and show the reading of AO1 error.
This wasn't hapening often at all and didn't seem to be a nuisance, however since having a water meter installed right below the flow of the boiler it's happened load of times.
I've tried differen t things to solve the problem.
1 ) I've adjusted the water pressure as it was on FULL after the water board fitted the meter ( well there's a surprise they did that after all they don't want me to notice having a meter would make a difference to my annual bill - THAT'S ANOTHER STORY )
Adjusting the water pressure seems to make a difference, if it is on very low pressure then it takes a lot longer for the boiler to 'cut out' and show the error message. ( this can be 5 minutes before it cuts out )
At full pressure the boiler heats up ( when tap turned on ) and basically switches off about 10 seconds.
I have read through the instructions and noticed that the potentiometers inside the boiler were on MAX ( these must have be reset to MAX after the last plumber visit because the firt thing he did was go into the box and have a play about ) I have now reset the potentiometers lower and have the boiler running at about 44C. This water seems to run a lot longer when not on MAX than when on MAX.
I filled a bath to 6 inches of water at 43C earlier but after about 8 minutes the boiler went to 44C then 45C then 46C then 47C then cut out....it was shjowing 43C for ages. The pressure of water wasn't adjusted during the filling and was kept constant.
Just though I'd mention. I have a gas meter Quantum which is a Pay as you go and now I'm on the emergency and have been during this period of boiler unrest. Any chance the gas meter is upsetting the system ?
I'm so glas it's summer and don't really need the hot water but would like to get it sorted before ASAP.
Any ideas folks....pretty please.
( a confused mind from Wales )
Notty
Notty
