They have not. Even in a flitched beam the steel plate sits on the bearing.In effect they have created a timber flitch beam
It's a frankenbeam. Burn it.
If the whole (steel + timber extension) was encased in fireline board, what would be the difference?Good point.... what would the fire resistance of that bodge be if the house caught fire.....?
Thick timber sections can be good at resisting fire for certain periods because the outer layers char, protecting the inner layers.I am not sure. As I recall steel fails when starts to weaken at temperatures above 300°C but is considered "safe" upto 800°C. Timber would be ignited at about 200°C
Do Building Regulations accept structural weakening / failure at temperatures not much above 200°C
Performance and failureIf the whole (steel + timber extension) was encased in fireline board, what would be the difference?
it looks like the new brick pillars are simply sitting on the concrete floor. Would that be standard practice?
____edit____ are concrete floors considered to have the same load bearing capacities as the exterior walls?
No, and no.
Thanks. Based on the photos do you agree that that look like they are simply sitting on the floor? Or is is possible that they are suitably tied into the existing walls.
In image number one they look like they are sitting on the floor tiles. In later photos it looks like someone has ripped up the floor tiles.
And is there a reason whey they wouldn't have just punched holes in the walls rather than build pillars.
Sorry, I only ask because I have no idea about that side of building.
I guess I am asking if the supports are sufficient regardless of the suitability of the RSJ.
Did you engage a structural engineer directly or did the builders do it?
Ring the SE and ask what his recommendation was in terms of RSJ dimensions and placement, that way you’re getting it all from the horse’s mouth and can direct the builders accordingly.
Erm, sorry Munzy, I was asking about the job that the OP posted. I know eff all about this stuff but my lay knowledge leads me to assume that things aren't as they should be (with regards to the OP's initial post). I am however happy to be corrected by members who understand more than I do.
Just to clarify, I am not the OP, but I appreciate that threads become muddied by people like me
