Hi folks,
I'm looking at buying a steel framed house, I think it's a Trusteel Mk1.
No survey has been instructed yet but on the viewing I noticed a doorway through the external wall of the house, which originally led to an outhouse/utility, has been enlarged from typical doorway size to around 2m to make the old outhouse a kitchen extension.
In the middle of the floor in this new opening was a steel I beam which originally ran vertically but has been cut out with an angle grinder in order to make the opening clear. This is about half way along the length of the house (ie it's not near a corner). The I beam is probably about 75mm x 75mm.
The owner claimed ignorance and implied the builder who'd done it had sorted it out somehow.
Obviously an engineers report will confirm what the situation is but my initial instinct was that this has probably been hacked out without any thought, and I might walk away without wasting survey money.
Anybody have any ideas on this? If it has been removed 'properly' how would it be done, by cutting it out and running a similar beam horizontally between the other matching I beams?
Would appreciate any comments.
Rich
Rich
