Its an interesting thread, and I certainly dont have any answers but would hope the OP comes back with news of whatever happens next?
FWIW:
The front elevation has very little in the way of brick panels - there are a lot of openings on a narrow front.
However, none of the heads or sills have dropped, and the eaves line seems level & the roof plane flat.
Same with the beds on both walls: pretty level.
Its a pre-1914 house with a slate DPC that also seems to be fine & level - the elevations would appear to be cavity walls.
Is the cracking at both sides of the corner (#2pic) dropping towards the base of the point loaded corner and the original gulley? I'm confused by the, for once, abundance of pics.
OP,
If you return to check the interior then have a look at the unequal roof join with next door.
FWIW:
OP,
