- Joined
- 13 Jun 2015
- Messages
- 5
- Reaction score
- 0
- Country
Good afternoon all,
First post here, so please be gentle...
I'm in the middle of adding an additional three 70w fluorescent strip lights to an existing 70w strip light in my garage (all run from a single switch).
Having made a similar addition in my last property (which is was a more recent build) I have wired the additional lights together in the same way using 1.5mm t&e.
However, having come to make the final connection to the existing light circuit I have discovered that the current wiring is 1mm t&e. Checking back I have discovered that this is the case through out the lighting circuit, all the way back to the MCB (B6).
Now, I know what I should probably do (i.e. strip out what I have done and start again with 1mm...), but would it be possible to step up the existing 1mm to 1.5mm, just for the additional three lights? Would it be unacceptable on the basis that anyone subsequently adding to the circuit would assume it was 1.5mm throughout, or is there a loading issue?
Many thanks for any thoughts.
