Well, it's inevitable that 1.0mm² is more likely to 'snap at terminals' than 1.5mm² - the question is, I suppose, how often that actually happens.
However, if they really were concerned about "snapping 1.0mm² conductors", they didn't really ought to have allowed 1.5mm² T&E, either - that has a 1.0mm² CPC, and a snapped CPC is probably a more serious/dangerous problem/risk than a snapped L or N - not the least because it is quite likely to go unnoticed!
The earth is usually static in the back box, whereas the switches were often on and off for decoraters, either residents or contracters, so maybe they encountered problems.
I myself in my career have encountered switches snapped off twice , both times 1mm, one a day after I actually fitted it, never used it since
Not sure it makes no difference, the snaps invariably where the insulations stripped and the cores scored, doubling over would possibly agrivate the score more.
Bit like a pyro ringing tool or a pipe cutter.
You aint lived
I know what you mean though, ovezealous tightening flattening it like a cobra snake head.
the snapping ive encountered is more found when prestripped ends have been reterminated after faultfinding etc
not just 1mm though, even 2.5mm
Even once found a pyro snapped at the gland,caused where the pvc sheath was took off by a stanley knife scoring the copper so deep.
Of course ideally any cable should be dressed so theres NO stress to cause snapping anway
