I have several radiator thermostatic valves sticking, either open or closed.
A couple of the radiators couldn't be shut off, so I removed the top part and pushed the pin down with the flat of a screwdriver blade. A couple won't open so I've tried pulling the pin up, but to no avail. These are "Westherm" valves which have been in for about 15 years.
I did flush out the whole system a couple of years ago. There are 2 drain valves under the floor hatch by the back door, so I connected a hose to each in turn, connected a mains water hose to the pressurisation point at the boiler and flushed the whole lot through for a couple of hours, closing/opening one radiator in turn.
1) Is there some way that I can add some "rad flush", for want of a better term, to my sealed system in order to get it free from crud ??
2) How often do I need to flush it through ??
3) Is there some "Stuff" that I could add to stop the crud forming ??
All advice much appreciated.
Jim
Jim
