- Joined
- 22 Aug 2006
- Messages
- 5,852
- Reaction score
- 718
- Country
Still doing it then. My advice then, is that you use a simulator until you're winning overall.
I can't be your teacher, I can only really tell you what I picked which worked for me. I've stopped trading every day now, though I usually look. When there's something moving a lot it's much easier. Bitcoin hasn't been behaving, most of the time. I have the bulk of funds in Funds and ETF's, which are harder to manage because of the delays
The one trade of yours I looked at was the one which lost the most. As I remember, it was just a popup, and you went long when it dropped back. There was no trend, and you stayed in it much much too long.
A rising trend is a sequence of higher highs and higher lows.
So where you're looking around your second label on the btc is more of a range because the pullbacks are such a large %, but yes it's rising a little on your btc chart. Not much of a rise, which later shows it's only consolidation. Did you compare with the previous days, MSTR, HUT8, etc.
You have to get your entries right. Wait for pull backs, always.
The rising channel is between the blue and green lines. Enter at a blue arrow, exit at the green.
15:06 is somewhere in the oval, so the wrong place to enter long.
You would have got out at the red arrow.
Black arrow looks like a breakout high may be starting, but it's a fakeout. MACD woud probably have shown you that was coming, if you had its numbers set right. The standard ones are too long for day trading on a minute chart.
You would have realised it wasn't happening and got out around the black blob.
The volume may have dropped too. Upward breakouts need an increase.
15:16 looks like a high (above the "a" of "upward" - definitely the wrong place to enter, though because you'd joined an uptrend , you should have realised and got out with your head above water at the red arrow.
MARA was consolidating too. BTC wasn't moving much. You can't use a micrometer for influence between names. AND remember they can go the other way.
Riot -
"Five reasons to short Riot today."
It did drop so you should have been up.
If you were looking for a short you would have been looking for highs as entries. If you missed the start of day, the reason for the short is probably gone. Indeed, you get a "double bottom" so would be expecting a return upwards, which is what happened.
Ifthe drop loos strong, as it was, then wait for a green candle, there were a couple.
Think you're taking too much notice of odd candles for a 1 minute chart. Look on the 5 minute for reversal signals. They're much less reliable on 1 minute unless big, or showing a rejection of a strong level.
Neal Roberts mid day short lessons are often good.
I bought NVD3 a couple of weeks ago to hold into the split which is Monday. It doubled do I sold some. I'm hoping for a bit more in the next couple of days, but I have tight stop. Wouldn't be surprised to see NVDA back at 900, ie 90 next week..
Some long-term ones I have are down quite a bit, like metals. Uranium, anyone?
I had a lump in China with a stop loss well below. A bloody wick went and hit it. Cost about 20k. Can't win em all.
SMB capital have a good 1 hour vid on becoming a successful day trader. First they do say, go off and learn the fundamentals, and a load of standard sequences. They list out several things which you have to get right.
Riot -
