Hi Guys, im after some advise for tiling my bathroom, i am going to be using 3 types of tile for the project, Travertine 400x600x10 for some of the walls, travertine mosaics (sheet format) for the remainder of the walls/in-set areas and calibrated granite (400x400x12) for the floor. Im going to have a bash at doing the job myself, so i am after some advice regarding adhesives, trowels and sealers ect.
1> The travertine 400x600 is going to be mounted onto part solid and part plasterboard wall, what adhesives and trowel size type would you recommend for this ? What tile space size would you recommend to give the best result ?
2> The travertine mosaics are going around the bath area, there is also a shower mounted above the bath. What tanking kit would you recommend for this (if any) ? what adhesive and trowel size would you recommend ?
3> The granite tiles (black) are being floor mounted onto chipboard floor paneling, What adhesives and trowel size type would you recommend ? im thinking about keeping the tile space size to a minimum for this and was thinking 2mm with black grout, is this feasible with this type of tile ? what are your thoughts ?
4> Sealers, what manufacturer would you recommend for doing travertine and travertine mosaics ? how many applications would you apply to the mosaics at the bath/shower area ?
5> Grout, what would you recommend for doing both travertine tile and mosaics ?
Many thanks for reading my post and thanks in advance for any replies.
Gavin
Gavin
