Talking of Arrows, any one want to guess what the arrow on the cheap isolating valves denotes.
Always thought it was the direction of flow so that crud didn't get into the circlip section and joint of the two halves - if that makes sense.
Direction of flow so you don't blow the circlip/ball out.
But if the valve is put in reverse, your still getting wet!The arrow points to the end that can safely be disconnected if the pipework is under pressure, otherwise you could turn the valve off undo the nut and the ball will fly out.
Just swap it back to the correct way..... simples
We do cheap imported Chinese, reasonably priced Italian and ridiculously priced real McCoy Ballofix isolating/service valves. None of them has anything like what you describe.if you look inside the service valve one end has a strange shaped partially coned perforated metal disc
But if you are wanting to work on this length of pipe with service valve in the middle. And you don't know the direction of flow, you would isolate it then disconnect the nut the arrow is pointing to, would you not? thus getting wet, but no blow out! If you disconnected the other end "your a crazy fool"Assume you have a length of pipe with an isolating valve in the middle.
You want to work on the pipe so you turn the valve off and intend to drain the end you want to work on.
But the arrow is pointing to the opposite end, therefore if yo drain the section you want to work on, leaving the other end under pressure, the little ball will fly out.
Hmm, you'd be surprised st some of the questions we get asked by supposedly qualified plumbers, heating engineers and mech services engineers!!if I couldn't tell the difference between an in-line filter and whatever this is I shouldn't be doing plumbing, 4years of college wasted.lol.
