I'm a diy'er who's in the process of fitting a bathroom suite and shower cubicle, but things are not going to plan......
The main stop-cock,where it comes into the house was very reluctant to turn off, it didn't feel just right, and took me ages to turn it off best i could .
Unfortunately, when i turned it back on later it developed a leak, a constant drip, the bugger filled a casserole dish every 20 mins!
I managed(eventually) to unscrew the brass nut(or what was left of it)and twist plumbers tape around the shaft of the handle,before screwing in the brass nut, the leak has stopped for now, but i don't trust it, and still, the water supply won't turn off!
I have took the cap of the outside stopcock, but no way can i get the 6 foot long key to locate/mate up with anything down the hole.
Basically, what i'm asking is, if i am unable to turn the water off outside, is there an easy way for me to repair or renew the stopcock pictured, or is it a job for a plumber?
The pipe below the stopcock is lead, the pipe above is copper.
My dad was told sometimes a plumber can freeze the pipes to renew the stopcock, is this correct?
If i do need a plumber, which looks likely, how much would i be expected to pay?
Thanks for any advice offered.
