Storage boxes for tools
Have a look at the Magnusson/Erbraur system. These are stackable, waterproof, some have wheels or you can make a trolley.
For the space that is around 1 metre deep and 60cm wide, I am planning to use a couple of boxes (probably really useful ones) and any space left across the 60cm width, I could create a "tray" which can hold stuff and be slid in and out. If that makes sense...
Again, please shout if there are any counters.
Thanks for your help.
I have a section of the shed that isn’t easily accessible and I want to put storage boxes in here, that I can drag out when required.
The space is 1metre deep, 69cm wide and I’m looking for something around 30cm tall. It could be two boxes.
I can find general purpose boxes but concerned they may crack with the weight of tools, etc. do you recommend something strong enough for this?
Thanks in advance.
Dexion slotted angle and plywood - 12mm should be ample if you have a crossmember under the base, and don't buy it in B&Q. Castor wheel at each corner. Shouldn't take much more than a few hours to knock up.
