Strange pressure drops
internal leak on the boiler means, inside the boiler not under the floorboards etc, that would be the ch system.
No water from condensation when stat down and heating off.
The system is cool and heating is off but pressurised. At about 1.2 bar. Will see what it is like at 6am.
Thanks for the help.
Pressure was 1.1 bar this morning. Heating has been on this morning and then off. When I returned from work at 6.30pm it was about 1.13 bar. I will keep the heating on for quite a long time and see if the pressure drops.
while its heating the rads check the blow off pipe that goes outside. (copper pipe) make sure all the rads are hot . also feel the blow off pipe along its length and see if it is hot.
