Hi all,
I hope you can help me with this. I have spent two hours with a CORGI this evening trying to work out what the problem is, but we haven't been able to. Boiler is a Potterton Prima 60F.
Its like this -
Call for heat
Fan starts (maybe not as loud as before, but that might be my hearing)
No further noise or action.
Manually sucking on pressure switch or bypassing it with a changeover switch at the right time will get the pilot light to ignite. Ignition sparks continue but main burner remains unlit. We have checked the pipes to the pressure switch and ensured the restrictor is clear.
Searching here hasn't revealed a solution, because it doesn't seem like a faulty pressure switch, more like lack of fan pressure, but overcoming that doesn't get the boiler lit. I have a wife off work recovering from a back problem and really suffering from the cold, so any help would be really gratefully received.
Its like this -
Call for heat
