Agile said:Repeat of what I said earlier as its still relevant:-
I dont remember if it will even work with cover off!
You dont say if the pilot lights ???
If not then he should have checked gas valve first stage to see if its powered and if so opening.
If it lights then the flame has not been detected if it keeps on sparking.
Tony
Thanks, Tony.
It will run with the bottom cover off. I'm not trying to start it with the combustion chamber cover off. After fitting the new pcb and calling for heat the relays click and the fan starts (although perhaps quieter than I remember it) but no ignition. If I bypass the pressure switch with a manual switch and switch over after the fan starts running the boiler fires, but then immediately switches off again.
