I'm so glad and relieved its all sorted now. Thames Water sent some third-party guys out to find out the cause of the blockage. These chaps were very generous and they decided to un-block the pipes even though it wasn't Thames Water's issue. I've updated the previous picture so you could see where the blockage was. They advised me blockage was caused by oil, grease and wet wipes (this is shocking!).
However, they advised me my property is the only one that's using that part of the chamber which I'm quite baffled about. Because if you look at the below picture you'll see its got quite a few connections coming into it. I took the picture while facing the house.
https://picasaweb.google.com/lh/photo/zMcUl-AG39BP1HkQZi3tTdMTjNZETYmyPJy0liipFm0?feat=directlink
Hugh my property was individually built in 1985 and yes its on slope. I was under the impression houses on the left hand side (while facing the house) might be draining in this one because they're on a slightly higher ground level than mine.
