- Joined
- 26 Sep 2024
- Messages
- 5
- Reaction score
- 0
- Country
I have an S plan system and over the last few days i've noticed strange behaviour which I hope someone can help diagnose..
When the hot water comes on (typically on a timer), the h/w zone valve opens, the pump starts and then the boiler fires up.. after some time, with the hot water still 'on', the zone valve closes and the pump turns off. Then after some more time the zone valve reopens, the pump starts and the boiler fires up.. then the cycle just repeats.
What used to happen was that once the hot water came on, the zone valve would stay open and the pump would run the entire time the h/w was on.. with the boiler firing up intermittently to keep the hot water cylinder hot.
Can anyone advise what might be causing this change if behaviour?
To add to this ( and I hope its not related ) i did have a replacement pump fitted a few weeks back.
