That's the white plastic cap retaining ring. But there is some string showing on the screwed joint for the drain cock. I thought it looked like hemp, hence my mention of an old plumber.
The cap is also used as a knob to turn the spindle.
You're right, I hadn't looked closely enough . Hemp used with Bosswhite or similar. Not to be used on gas as the joint is porous, but it was in my first house, and it smelled slightly.
