Stripping wooden windows
trotter said:
oilman said:
If you are going to take out the old putty, you could try Setting up a router to do it, just skimming the wood. If you have bare wood where the putty will go, you need to paint on a coat of shellac to stop the oil being dragged out og the putty.
Are you going to use linseed oil paint?
I might well do, would you recommend it?
Would you use linseed oil AND shellac on the bare wood before puttying / painting? Or is it a case of choosing one for the job?
And does this affect the paint I should use?
i would personaly say a router would be a little impractical
you couldnt use a router bit with a bearing so you would need to secure battons to run against
you would also not be able to router the edges because of the frame and the baseplate
i also am not shure how the cutters and glass will interact where they touch
as well as said above the pins [brads ]holding the glass in not only will they catch on the router cutter they will probably be proppeld in a random fashion
much better to use an old chisel at rigt angles to the glass tapped in parralel with the glass along the rebate ;)
JohnD said:
This is the wrong time of year for painting external joinery.
I suppose you could take the casements (or sashes) off and bring them inside to dry out for painting... you will be able to paint the frames better that way too ;)
That's the plan John, hence why I need the quicker drying paint...
Thanks for the replies but just to reiterate my question:
Will Dulux 'fast drying' gloss work OK with Dulux 'primer and undercoat in one'?
Only reason I ask is that the gloss states it doesn't need an undercoat but as Joe said earlier in the thread - undercoat makes for a better job...
