Morning all,
We've been experiencing an intermittent strong 'cabbagey' smell in our bedroom for a couple of years now. We can go for days without smelling anything and then other days it's quite noticeable? The other bedroom adjacent to ours can also sometimes have the same smell and the loft space also fills with this smell. The strongest point seems to be around our headboard area which is up against the wall (adjoining to our neighbour - it's a semi). If there is a stronger than normal wind outside, this also seems to make it worse?
Now, right behind our bedroom wall runs a flue pipe from where was once a gas fire. The fire has been removed and the wall boarded up to make a plain wall (there is no chimney breast as this is a 30 year old house and the gas fire would have only been a small one originally). I can see the flue emerging into the loft and up out of the roof.
Could this smell be anything to do with the blocked off flue downstairs? Smell is only noticeable upstairs? Could the wind be making a difference?
Our neighbour does not have the same problem but their gas fire is still in place?
Any ideas out there please or a I barking up the wrong tree with regards to the flue?
Cheers all.
Cheers all.
