Hi Guys,
I recently serviced an Ideal response 120 and after finishing the boiler will not light in CH or DHW.
I damaged the seal on the Pressure sensing pipe. The one at the back of the plastic bit that screws onto the fan and i have also misplaced the square gasket at the end of the pipe where it screws into the manifold block. I have tried parts centre but because the manual doesnt quote any numbers they cant order them.
I have manufactued some replacement gaskets from High temp gasket but im not sure if they are working properly.
Where the pressure sensing pipe screws onto the manifold block is the hole at the top right hand corner suppoused to be open or closed over?? I also notice dthis was bunged up with dust etc. Cleaned it out as best i could. If this was blocked would this stop the burner working??
I also replaced the electrodes as i damaged one when taking out the burner assembly. And i have have both sensors out to check thay were okay.
Think that is everything i ahev done. Any ideas as to what is happening??
Grill
Grill
