How do I free? (mixer tap is leaking, needs new washer / disc)
Its a compression fitting on sink hot tap (the inlaws).
Unfortunately its already had its screw slot a bit chewed.
I thought heat might work, then penetrating oil.....
system is in a bungalow, hot water tank same level as boiler, seems to have pump on hot water from boiler to tank coil. Havent looked to see if there is a stopcock on the hot water out of top -is that likely?
Cheers
Cheers
