Sub-circuit off ring main
25 Jun 2007
Merseyside
Hi.
I'm doing some electrical work in the kitchen of my new house and I've found the wiring for the garage has been taken from a junction box spurred from the socket ring main. It looked a bit dodgy so I've disconnected it all but I need to reinstate it. Can I make a small sub-circuit/ spur with a two mcb consumer unit on the ring main pretty much as it was or do I have to start back at the main fuse board? I hope that makes sense to those in the know.
Cheers.
You can take a spur from a ring to feed a garage. Assuming:
a) the cable going to the garage is the same size as the cable that makes the ring (usually 2.5mm²)
b) the cable is properly protected (eg armoured if buried)
c) there is an RCD either protecting the ring circuit or protecting the sockets in the garage itself
Do also remember that any electrical work carried out in a kitchen or outside (eg garage) must be notified to the local authority before the work is carried out. (See WIKI)
Thanks for that.
The original cable that runs from the house to the garage presently is armoured as it's buried (albeit not very deeply) so I'll reuse that pretty much as it is for the moment.
There's no (new style) circuit breaker on the main ring just the original 30A fuse in the fuse box. Between the ring and the garage I'll put a small circuit breaker located in the kitchen.
I've been on to the LA and they're coming out to have a look at the first fix soon so fingers crossed everything should be OK but I just needed to check some of the less obvious fundamentals beforehand.
Cheers again.
