Provided there is no risk of clay heave etc, then concrete every time.
Practical.
Simple.
Economical.
Solid.
Efficient.
No.Lets say you were building a new extension that joined onto an existing room that had a timber suspended floor (with about 4 foot head height under the floor)
Would you still make it from concrete with ducts to maintain ventilation to the original floor?
Maximum depth of infill should not exceed 600mm otherwise a suspended floor should be specified.
Otherwise yes we would and do as you say extending the existing vents to the new outside walls via ducting and air-bricks.
at least we'll be able to break out the existing concrete subfloor at the back of the house
How thick is this existing slab, and how much lower than the current internal floor level is it?
There is a cheat
aah geddit now.Basically my kitchen was at the rear of the house and the extension was built outwards from there. The kitchen (like all of the ground floor) has a suspended floor with a 3-4 feet of void underneath. The extension has a solid floor.
