What - prior to planning approval? Why?I disagree, in my experience the input of a structural engineer at early design stages can be invaluable.
I’ve worked on many projects where in order to design extensions / loft conversion it’s been helpful to understand the existing structure. It’s often useful to get a structural drawing of the existing building. This can show what elements of a building can’t be removed, what can be removed with serious structural intervention, what can be removed with minimal structural intervention and what can be removed with no structural intervention.What - prior to planning approval? Why?
They won’t know everything, unless they are a structural engineer. We’ll have to agree to differ, I know my approach works.Sure but a good designer will know all of that and without any need to employ an SE.
You must know everything thenSure, I guess if you don't know so much.
Doesn't explain.I’ve worked on many projects where in order to design extensions / loft conversion it’s been helpful to understand the existing structure. It’s often useful to get a structural drawing of the existing building. This can show what elements of a building can’t be removed, what can be removed with serious structural intervention, what can be removed with minimal structural intervention and what can be removed with no structural intervention.
With this knowledge it can be possible to design a scheme with less or no structural alterations. This can be more economical for a client. Especially those on limited budgets.
It’s better to design a scheme with the full structural knowledge of building than find out post planning that you need to use a huge amount of steel for example, when a different design approach that satisfies the brief could have avoided these unnecessary structural costs.
only a fool...I guess so, yes.
Explains very clearly, working around an existing structure rather than removing or altering parts of it unnecessarily can save clients money, knowing this in advance of designing something can be invaluable and avoid costly design solutions post planning.Doesn't explain.
Designers know enough to show details on a plan drawing. No need for SE design input early on.
Come on, really, for an experienced designer what is there to know about loft conversions and dormers, it ain't brain surgery. This is actually pretty low brow stuff in the world of building design.only a fool...
as i said, only a fool...you must understand every type of house construction that's ever been used, and every permutation of loft dormer and loft conversion design that could be possible then, silly me.Come on, really, for an experienced designer what is there to know about loft conversions and dormers, it ain't brain surgery. This is actually pretty low brow stuff in the world of building design.
But that is always solved with a wee bit of to-and-fro with an email or quick chat or text, between the SE and the designer. I have never heard of a client shelling out for an SE at the planning stage before. Unnecessary waste of money.Explains very clearly, working around an existing structure rather than removing or altering parts of it unnecessarily can save clients money, knowing this in advance of designing something can be invaluable and avoid costly design solutions post planning.
