Hi guys I have some normal recessed downlights i.e. those that require a cut out of around 75 mm
Now I have a small triangular shaped room which has two sides around 200 inch, one side which is 160 inch and although it looks like a triangle it has a top side which is 60 inch
Now the problem i have is that using several stud detectors I can not locate the studs/joists in the ceiling and I was intending on fitting these lights in two lines consisting of 5 lights each. What would you guys recommend
I really do not think I will be able to get away with this without hitting a stud hence the reason im planning on drilling some pilot holes but nevertheless what would you guys do?
I also thought of getting something like 18mm MDF, attach the lights to that and hang that off the ceiling around 2 inch but would prefer not to
Likewise, all suggestions welcome guys
