Sorry I wasn't clear.
If you put down the outer joists, then put a timber closing off the ends, that forms your base, then all this joists in between and screw in place - if they aren't sitting on a block they need joist hangers.
Then you can put your stud walls on top.
I did double joists at the end with a spacer, so there was something for the floor OSB sit sit on.
Ok, I’m with you now. So you mean build a frame and then joist in between it, fix floor deck then build up off it ( or walls up first then deck) Floating floor and not fixed down.
I’d have to have vents in the concrete blocks for this ?
I was talking screw sole plates for walls to outside of concrete block and then put joists on the inside of the concrete block. This way I thought the floor deck will be higher than sole plate for walls and Creates ventilation to outside via the breather membrane gap.
