I've been planning a self build garden office/gym for a while and ultimately want it to fall within permitted development. Lots of build resources are available and it will be a fairly simple insulated timber build with a cold flat roof. However I am limited to the 2.5m height rules as it's a mid terrace garden, which limits exercise possibilities with anything overhead.
Ideally to make it a more usable space with sufficient head height 3m height would be better, but I just think that height will look quite "oppressive" at ground level, even if PP were approved (and I could see why neighbours would oppose).
I'm trying to research the idea of digging out c.1m and building a retaining wall (thinking concrete or blocks), then siting the building within the hole, giving me sufficient internal head room whilst also keeping the building height to c.2m above ground level.
Has anyone done this or can answer the following questions?
- would I need PP for the dig out if building area remains within my permitted development floor area?
- how much gap around the building walls would I need for suitable airflow.
-could I just use well draining hardcore and shingle base with building mounted on foundation ground screws, or would I be better doing a concrete base and looking at sump pumps.
I'm not sure of the water table level where I live (flat area in SE london), so I'm thinking of digging a small bore hole to the planned depth to see if it fills.
Any other ideas or links to online resources without having to employ a professional?
