sunvic 3 port valve replacement
Bung, repair kit, refill & test - about a half hour job, or buy a whole valve body if you want - Ive got a couple on the van ;)
Why the 13amp fuse?
Mr. W.
thats what was in when i opened it what size should it be duh looked at the box just saw the 5 amp rating on it :oops:
hi guys, i had a sunvic douval 3 port valve, which was leaking for god knows how long, on to the pump hence scaling up all pipes and pump, causing the fuse on mains supply to blow every time power was turned on. now i have had the diverter valve and pump replaced by my plumber.
now the problem is, that boiler fires up with the cylinder stat on demand. but does not do the same with the room stat, meaning the heating would not come on through the room stat. it would come on though, if diverter valve manually opened.
can some one kindly help me out
