Snowplough, this is really important if you are ever going to understand earthing and bonding.
The incorrect use of terminology is at the heart of many misunderstandings in the electrical and associated trades about these practices.
The first thing you have to do is understand the difference between earthing (exposed conductive parts are connected to the means of earthing via the circuit protective conductor, the main earthing terminal and the earthing conductor) and bonding (exposed and extraneous conductive parts are connected together [equipotentially bonded] by main and/or supplementary protective bonding conductors).
Get all those definitions straight before you start to read or listen to any explanations people give you. This includes any advice from your lecturers.
If you have a copy of BS 7671, memorise the diagram at the top of page 32.
Earthing provides a fault path (earth fault loop) to disconnect the circuit in the event of an earth fault current.
Bonding is there to reduce to a minimum the potential differences between exposed and extraneous conductive parts during the time it takes to disconnect the circuit.
Confuse the two and you're back to square one. Get it right now and it will stand you in good stead for the rest of your studies. Good luck.
