Hello - I need to move the routing of my three phase supply but have come up against a bit of a problem.
The supply is buried (only about 150mm) and runs across the garden then underneath the footing of a retaining wall, before running under the rear slab of the house, emerging from under the floor in the rear hall of the property, into the meter.
I need to remove and replace the retaining wall which it runs underneath, so I’m looking to have the supply cut just prior and diverted away from where the new footings will go.
The issue is, because of the building layout, there is not enough room for National Grid to cut back into the supply before it runs under the rear slab.
I’m wondering if the best solution is to terminate the supply in a new outside box and duct the cables along internal walls to the meter; or terminate the supply externally AND reposition the meter to an external box, and then run the tails from the meter to the CU through ducting.
Obviously I’ll not be doing any of this - I just need to get some feedback on possible solutions. TIA!
