supply setup
RMS said:
Job_n_knock said:
Modern digital domestic meters have 2 terminal covers on them. This is so that Contractors can isolate and rewire the tails. Where outside meters are used, some supply authorities require a double pole isolator where the tails enter the building.
but should the double pole isolator be used to isolate both live and neutral conductors to the installation?
that is the question :eek:
I say yes, and I would do it. Someone mentioned earlier about the neutral being the earth condutor in a PME system, BUT this is only as far as the service fuse. So why not switch the neutral after this? There is no reason not to AFAIK.
