ChrisR said:If the boiler was staying on longer before then it must have been getting hotter - try turning the boiler stat up!
Sounds like you need a new pump - perhaps it's now so knackered that it's hardly pumping any heat out so the boiler heats up quicker and turns off...
Thanks Chris,
I'm not certain the boiler did stay on longer. I wouldn't know. I'm not sure the pump is the cause because it was the pump that stayed on all day every day before the new board - but if Baxi-Potterton are to be believed, should have stopped/started, and the behaviour only changed on the change of the PCB. The pump may not be as good as it was but it doesn't seem likely logically to be the cause of the change in behaviour.
