Bit of a long one this, but trying to cover everything:-
Suprima 70 (12-15 yrs old) in open system. Boiler fitted in garage.
Have had to reset boiler quite a few times recently and everything points to the PCB. Have just bought replacement, but before I fit it (and can't take it back for refund):-
Heating system has started banging (middle of night when no heating or hot water on). Presume this is because the frost stat is kicking in and starting the boiler up. Pretty sure it's kettling (hot water going back to F&E tank) as have had problem before but not for ages.
Banging lasts for 30 seconds or so then stops, then starts again after a few minutes. Interval between it restarting varies.
Had heating on all day for several days recently and no kettling and other than the resets it's been fine. Seems weird that it would only happen from frost stat although does coincide with the cold weather.
Green light on front panel flashing. Red light on - book says this is call to heat, but boiler has reached temperature, so not fired up.
Had heating guy round a day or so ago and he said pump working fine BUT at that time we weren't getting the kettling. He asked about kettling, but I said we hadn't had it for ages.
Boiler thermostat seems to be working fine as it shuts down when the stat is turned down.
Don't think it's a sludge problem as had radiator off recently and water clean. Although I do appreciate that this doesn't necessarily mean boiler/pump are clean.
Don't think it's an air lock as nothing has been changed or interfered with for ages (I know this isn't a guarantee).
Questions:
1 - Could it all be linked to the PCB, so it's worth fitting it?
2 - should I be replacing anything else at the same time - temperature sensor, overheat stat, etc?
3 - What else could it be?
Been awake for 2 hours since 2am with intermittent banging of pipes, so hope someone can help.
Questions:
