suprima 80 PCB
26 Dec 2004
What is the latest part no for the new PCB and where is the cheapest place to buy one?
Sounds like I have the common resetting problem
Chris R - can you help?
Mark
As far as I know the latest pcb for the suprima is 5111603 which replaced 5102160. I replaced a older version about two years ago with 5102160 which has been satisfactory. (at the time 5102160 was a new version).
Pricewise the latest version is in the region of £180.
:rolleyes: :rolleyes: :rolleyes:
The 5102160 is, presently, available from HERE for £42.00 (including delivery), but you may find others if you do a search there.
would strongly advise against buying a PCB this way as you have no idea if the bleedin thing works or how its been stored.
:D 5111603 is the latest pcb for the suprima, the original pcb has a terrible reliability problem, i should know i used to work for potterton. The new pcb will cost you £140+vat from HRPC. All the best :LOL:
ISTR that to fit the 'latest, latest' rev of the PCB you need a fitting kit, with new wiring, as well as the PCB itself....
(And yes, instead of admitting that the previous board was a piece of junk and taking the cost 'on the chin', good ole' Potty are charging the FULL COST of the board AND the extra bits to the unfortunate owners of the old PCB when (not if!) it goes bang.)
