Hi folks
I have a 1900 era cottage style end of terrace house.
The front living room is a suspended wooden floor. Beneath it is about a 1 meter void.
I keep getting really high humidity in the room sometimes 70+% at 16-20C
I bought a dehumidifier and leave it running all night to get the humidity down to 55ish % but turn it off and close the door and leave the house all day humidity will quickly shoot back up.
I believe the moisture is coming from the ground below the void.
I have read about putting down plastic sheeting to help matters, but my problem is the room has laminate flooring on top of hard wood and then all the skirting built onto power of the laminate along with a cast iron rad and fireplace, so taking the floor up is virtually a no no.
Is there another option I could look at. Possibly taking out bricks from down the side to enter the space or is this just stupid?
Any practical advice really appreciated.
Last winter I had quite a bit of mould on the soft furnishings and don't want the new sofa to go the same this winter.
As you can see I have a total of 5 unblocked air vents and good ventilation in the room itself with an open fireplace and trickle vents in the windows which I hoped would help
Cheers
View media item 94838 View media item 94839 View media item 94840
Cheers
