A kitchen is to have a new ceiling put in. Sounds like some sort of wood effect pvc.
What sort of distance is required from the top of the old ceiling to the bottom of the new ceiling to accomodate lights? The lighting for the kitchen will be your standard spotlights and i am concerned about clearance and heat build up.
Also, the floor in the room above is wooden. For this reason work will need to be performed from below. The intention is to crimp a joint at the ceiling rose and run of this with cable to txs etc which will be accessible. Can anyone think of any problems to be aware of?
thanks again
thanks again
