Hi all,
I am about to get a concrete base laid and as its a concrete sectional garage going on top i need to run the electrics through the base as the panels cant be drilled on the garage. So I want to get the cable run now.
My intention is to run the cable for the garage then have an electrician connect it up when Its ready. I will leave the trench open and there is plenty room under the floor boards (4ft) so the electrician can check the run if he wants. The total run from meter cupboard to garage is 15m, 4m of it is under ground.
I have a few questions:
1) When I asked about this before on this forum I was advised that 10mm swa 3 core would be fine for this run, would there be any harm in doing it in 16mm? I dont mind paying extra if it gives more options in future. For example I may build a shed behind the garage that would need power.
2) Is the required depth 18" for the trench ?
3) What protection should the cable be in underground? A friend told me that 100mm waste pipe would do but he is not an electrician, does it need to be more substantial than that? and is there a particular colour?
4) What should I use to protect the cable inside the concrete? Some kind of conduit?
Many thanks in advance for your advice.
Pippo
Pippo
