well as i said screwfix etc and the only one on screwfix is a 1.5 mm and i wanted a 2.5mm so you just proved me right good job lol., and to taylor no its staying above ground and i was planning to clip it to the wall
If there's no danger of mechanical damage then the main issue with being outside is UV from sunlight.
You can get cables like this: https://www.tlc-direct.co.uk/Products/NY1dot5slash3.html
which are UV-resistant, however a lot of people would probably use regular flex.
thanks endecolp for your help and ban all sheds your nothing more than a forum troll, as i told you what wire it is and its not just a regular flex and the only 2.5mm on screwfix are for 15 metres or more when i only need 5 its clearly not a option
Just about every electrical distributor sells SWA by the length and will sell to non-trade customers.
You are really making this so much harder than it needs to be.
You've never said how long it was going to be, despite being asked.
If you need 2.5mm² (which you keep insisting that you do), then the ONLY reason for that would be that you need 25-30m of flex.
You can cut flex to the length you need with ordinary wire cutters.
As for me being a troll, please show where I have deliberately written something inflammatory in order to provoke an argument or to upset you. Feel free to remain rational and intelligent when doing so.
