Called out to an underground SWA cable (6mm) having had a small piece of outer sheath sliced off by a garden spade........ Well it was a digger actually.
Steel wire only superficially marked, and no reason to suspect that the insulation or cores were in anyway damaged. I decided a good helping of heavy duty Gaffa tape was all it needed.
Ideally it would have been good to do cont & insulation tests, but really not needed going on appearance.
What would others have done?
